Liked 5 Times in 3 Posts
Hey guys dad has a ? for ya.... we put a new engine in his car just before labor day. The car ran fine BUT @ a race in late Sept. the car lost .12! Now we can't find it ? we have checked or changed everything! We've had jets in it from lean to smoking fat no differance . We have changed tires & wheels . Changed timing , fuel , launch points from 2000 to 3500. The car also lost about 2 mph? ( this is all 1/8th mile) Thing is it's running in better air now then it was Labor Day? 0h cam lift is good too?? Any ideas?
Liked 11 Times in 8 Posts
I'm going to assume no datalogger, Given the fact you;ve changed most everything as far as engine tune, i'd have to lookat torque converter? Really not enough info to make a really good guess however converter can definately cause this without any obvious symptoms. Joe
Joe Buchanan SS/BX 3117 |
Liked 18 Times in 12 Posts
Torque Convertor.
"Real Race Cars Have Tailgates" |
That would make some since. The car also slowed in reaction time...as in dad went up some 10lbs in front air pressure to try & cut a light!
Greg,
I've been told that this guy does a Killer job building convertors. Click here: http://www.ultimateconverter.com/testimonials.html
I agree, converter has a problem!!!
Shawn
Shawn Blair 6383 SS 634 STK |
Liked 364 Times in 138 Posts
Park the Nova; race a Maverick.
Dave Turner SS/GT #1153 |
Liked 5,077 Times in 1,935 Posts
If it is the converter, there will be obvious symptoms and it won't last long.
Is the stall really high or low? Trap RPM real high?
Mark, I stated no obvious symptoms because most of the converter issues I've seen guys have other than an obvious ET change They are unaware of whats "different" during their run. With a datalogger it's pretty easy to see it, even a playback tach helps. A just complete failure is easier to diagnose than a damaged converter. You are correct in they should be seeing something different in stall speed or finish line RPM. Hope you all find your issue. Please post your findings. Joe
Liked 320 Times in 102 Posts
Just like the old days.........
Flying by the seat of your pants...... NO MPH............ A good place to start is SPRINGS or RINGS Bob
