Liked 14 Times in 11 Posts
I got my shiny new TAYLOR battery box yesterday and am wondering
about the mounting of it. Read through the NHRA rule book and only find a reference to 1/2" bolts (2) for a weight box bolted through the floor/frame rail. Same for a battery box or just the two threaded rods through the box and trunk floor?
Phil Saran Parker, Colorado |
Liked 883 Times in 237 Posts
The box and battery should both be bolted THRU the frame rail , or a suitable crossmember. The box with at least two 1/2" bolts and the battery hold down with 3/8" or larger. .....The sheetmetal of the floor wont hold up against the mass of the weight box or battery in the event of a crash. ...........Tom
Tom,
Thank you, then I can mount the battery box the same way I did the weight box in my old stocker, with 2 1/2" bolts through the trunk floor and the frame rail on the right side. Man makes plans, God laughs.
Phil Saran Parker, Colorado Last edited by Philip Saran; 10-14-2009 at 04:58 PM. |
Liked 717 Times in 220 Posts
You're getting close....
" Man proposes, God disposes"--- U.S.Grant |
