Old 10-04-2009, 10:16 AM   #1
sportsfan
Default Adjusting valves on cold engine
I need to adjust the valves on a SBC.It has a Crower solid cam,clearances are .022 intake and.024 exhaust with engine hot.Problem is I can't warm the engine in my neighborhood.What clearances should I use with the engine cold?
sportsfan is offline   Reply With Quote
Old 10-04-2009, 01:13 PM   #2
Liked 1,914 Times in 429 Posts
Default Re: Adjusting valves on cold engine
For cold valve lash, for the first time start up:
With an iron block and iron heads, I set mine about 0.004" to 0.006" loose. With an iron block and aluminum heads, I set mine about 0.006" tight.
Hope that helps.
Old 10-06-2009, 05:16 AM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Alan;
Do you use the same "rule" for a solid roller cam?
Old 10-06-2009, 06:48 AM   #4
Yes Bob, I do. It seems to work pretty well. I tend to err to the tight side on lash, as a general rule, I don't like stuff bouncing around loose.
