Liked 3 Times in 1 Post
I need to "settle" in on a spark plug since we can't currently run the adapters. Has anyone had luck with a particular brand and heat range? I ran the 137 Accels and the Autolite 3933 (I think that's right) but didnt see any difference. I was having some oiling issues at that time, which may have hampered the "testing".
Any help is greatly appreciated...... See you all at INDY!!!!!! Wade O |
#2 | |
I don't know about others, but I've been an AC Delco Rapid Fire fan for most of this decade, and I won't forget that my used set of them outperformed a new set of Bosch Platinum + 4 plugs I tried around 2002. I'm not sure about heat ranges though, because I've just been using the OEM recommended part number for my application (which I know is no help to your set-up). I'm also curious about those E3 Diamond Fire plugs, but if I find out that their foreign made, they won't go in my car...good luck at Indy! I'm amazed that you haven't gotten any replies to your post prior to mine, but I think most of them are on the racing side of the Stock/Super Stock forum....
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) |
I like NGK's in my 10.5-1 505, I change plugs once a year.
*** 72 Malibu *** 1.329-3.99-6.28@106.71-9.98@131 best 60ft to date-1.2997 |
Liked 279 Times in 96 Posts
NGK's race plugs work good and cost $2.50-$3.00 a piece.
Mike Taylor 3601 |
Liked 5 Times in 3 Posts
I run the Autolite race plugs...it's what Bruce gave me.
