Old 08-03-2009, 07:46 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default manual trans racers, what do you do about not having a "park"?
The though just came to me, since I no longer have a park, this will require some new discipline when running the engine while not seated in the car. [adjusting timing, adjusting carbs, etc]
And of course, I have no park brake system because it is a race car. So, how do you manual trans racers address this "non-park" issue?
Thanks
Larry Woodfin 471W
Old 08-03-2009, 07:56 PM   #2
james schaechter
Liked 1,424 Times in 294 Posts
Smile Re: manual trans racers, what do you do about not having a "park"?
Someone is in the car when we do that. We also carry a wheel chock to put behind a tire when it is in the pits unattended. Just in case.
James Schaechter 3163 STK
Old 08-03-2009, 08:24 PM   #3
Philip Saran
Liked 14 Times in 11 Posts
Default Re: manual trans racers, what do you do about not having a "park"?
Carry a floor jack and a set of jack stands and place the rear
axel up off the ground when your working on the car.
Plus a wheel choc or two for safety.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 08-03-2009, 08:27 PM   #4
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
If you run NHRA, General Regulations # 9.14 states that a driver be seated in the car in the normal position anytime the vehicle is running. As for a park brake, I use a block of wood if I think the car will roll or leave it in gear.
Dinsdale is offline   Reply With Quote
Old 08-05-2009, 05:34 PM   #5
alan r caraway
Thumbs up Re: manual trans racers, what do you do about not having a "park"?
Big Rock
Alan R. Caraway
alan r caraway is offline   Reply With Quote
