Old 07-11-2009, 06:55 AM   #1
bkeesee
Question Lifter Bore Repair
I recently moved to eastern NC (Greenville area) and I am looking for a honest, reasonable, quality machine shop that can repair (bush) worn lifter bores in a small block chevy. Only one bore appears worn but it may be more after miking Thanks for any suggestions you will share.
Brett
bkeesee is offline   Reply With Quote
Old 07-11-2009, 08:23 AM   #2
Bill Grubbs
Liked 564 Times in 66 Posts
Default Re: Lifter Bore Repair
Heintz Brothers!!!
The main shop is in Statesville, but I know they are also in Concord. Mike races Super Stock. Their work, and customer service are second to none. They are also very responsive.
www.heintzperformance.com
Toll Free:1-877-562-7373
Ph: (704) 455-9422
Bill
Bill Grubbs is offline   Reply With Quote
Old 07-11-2009, 08:39 AM   #3
RJ
If allowed for your class, another option would be to have the lifter bores taken out to .875", and run that size (Ford) lifter.
RJ is offline   Reply With Quote
Old 07-11-2009, 05:57 PM   #4
bkeesee
No rules that would stop me from boring them to a Ford size but I still need to find someone to do the machining.
Old 07-12-2009, 04:56 PM   #5
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
bud rowe in bridgeton nc
jim powers is offline   Reply With Quote
Old 07-12-2009, 09:57 PM   #6
bill dedman
Liked 6 Times in 4 Posts
I don't know whether it's feasible, but the Mopar lifters are the biggest diameter, at .904".
If that would work for you, and bigger is better, it might bear looking into.
Then again, maybe that size won't work in your engine... Check it out.
Bill
Bill
bill dedman is offline   Reply With Quote
Old 07-13-2009, 06:37 AM   #7
BlueOval Ralph
Banned
Wrong again, Mopar not biggest @.904 Oldsmoble had lifters @ either .924 or .930.
QUOTE=bill dedman;129586]I don't know whether it's feasible, but the Mopar lifters are the biggest diameter, at .904".
Bill[/QUOTE]
BlueOval Ralph is offline   Reply With Quote
Old 07-13-2009, 07:33 AM   #8
Tracy Robbins
Liked 25 Times in 11 Posts
If you are in eastern NC you should contact Doug Hobgood @ H & F Performance in Wilson, NC. They do our engines and many class racers from this area. You won't find nicer people to work with. Their number is 252/243-2050.
Tracy Robbins
SS 9766
Tracy Robbins is offline   Reply With Quote
Old 07-14-2009, 07:06 AM   #9
bill dedman
>>>"Wrong again, Mopar not biggest @.904 Oldsmoble had lifters @ either .924 or .930"<<<
Thanks for that information. I am sorry for the mis-information. I wasn't aware of the Olds lifter diameter.
Was that ALL Olds lifters, or just a select few applications?.
Bill
Old 07-14-2009, 09:19 AM   #10
BlueOval Ralph
Banned
Can not remember which was which as some blocks had different lft bore bore angles.
QUOTE=bill dedman;129815]>>>"Wrong again, Mopar not biggest @.904 Oldsmoble had lifters @ either .924 or .930"<<<
Was that ALL Olds lifters, or just a select few applications?.[/QUOTE]
