Old 05-04-2009, 07:44 PM   #1
Marty Hignight
Liked 23 Times in 14 Posts
Default Spring weight and Lenght
Need advice, i have a mustang with a tubular front k-member and tubular a-arms with coil over shocks, i am going to switch to 90/10 front struts but need advice on the spring weight and length. the car weighs about 3000 w/me not sure of the front/back weight, thanks for any help offered.
Marty
M204
Marty Hignight is offline   Reply With Quote
Old 05-05-2009, 10:09 AM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: Spring weight and Lenght
I have 14 inch 150 rate on mine 3000 lb. car 1633 weight on front. Would help to know frt. weight is this small or big block? Joe
Joe Buchanan SS/BX 3117
Old 05-05-2009, 06:46 PM   #3
Marty Hignight
Joe it is a 347 small block, i have never had it on a 4 wheel scale, i have taken alot of weight off the front. is yours a full body car.
thanks
Marty
M204
Old 05-06-2009, 07:04 AM   #4
buzzinhalfdozen
Yes , backhalf SS car full interior. I run a V6 however it is very heavy, I know the bare block is as heavy as a production 351W block. I believe the 150 rate spring would be very close for your app. Joe
Old 05-06-2009, 07:35 PM   #5
Marty Hignight
thank you for the info Joe
Marty
M204
