Old 04-03-2009, 10:08 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default LS series, 6.0 iron block overbore allowance
Tell me about the 6.0 iron block cylinder wall thickness. Is an .030 overbore acceptable for 575 horse combination? [Carburetor, no power adders]
Thanks
Larry Woodfin 471W
Old 04-03-2009, 06:48 PM   #2
RJ
Default Re: LS series, 6.0 iron block overbore allowance
I've never sonic checked a 6.0 block, but have seen a report on one that was done. Worst hole at stock 4.000" bore was .098" on non thrust, .295" on thrust side.
RJ is offline   Reply With Quote
Old 04-06-2009, 01:22 PM   #3
formula447
formula447's Avatar
.30 over on a Cast Iron LS Truck block is fine.We make over 700 NA Flywheel Horse on one and have never had a problem.
.30 over(4.030) with a 4" Stroke Crank is the Common 408" Combo that just about all LS Builders Sell.
Ray T
formula447 is offline   Reply With Quote
Old 04-07-2009, 08:21 PM   #4
Chris Cogan
Chris Cogan's Avatar
Try to find a pre 2005 (GEN III) version 6.0 block as they do not have the LOMA bosses added in the valley. This will save you approximately 15 lbs of mass.
Chris Cogan
Chris Cogan is offline   Reply With Quote
Old 04-10-2009, 07:47 PM   #5
TOSTO RACING
TOSTO RACING's Avatar
Liked 652 Times in 184 Posts
You can take some 6.0 blocks .060 I ran my old setup .030 over and made over 700 horse and had no problems at all.
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is offline   Reply With Quote
