01-05-2010, 11:55 PM | #1 |
Trans Trigger
I have seen a lot of posts on other forums about the Trans Trigger but have never seen where you could purchase one. Anyone Know??????
01-06-2010, 06:54 AM | #2 |
Re: Trans Trigger
Call Danny Waters Jr @ 252 525 1605
Danny Waters, Sr / 73 Duster "340" |
01-06-2010, 08:58 AM | #3 |
Liked 9 Times in 3 Posts
Re: Trans Trigger
ok i'll bite. what the heck is a trans trigger ?
Mark Markow 171 ss/tb |
01-06-2010, 09:09 AM | #4 |
Re: Trans Trigger
01-06-2010, 08:45 PM | #5 |
Re: Trans Trigger
It is a device in which releases the trans-brake. Rather than a button and mashing it , you actually squeeze a trigger as if pulling a gun trigger. It looks kinda like a quarter stick pistol grip with the lever in front of it (like the part you squeeze to change a gear on the quarte-stick) it is spring loaded . When you want to release the trans-brake all you do is pull the lever while holding the pistol grip in the palm of your hand.Takes away flenching and other variables. Very trick peice. My son has wom numorous rounds with this thing.You also cannot accidently go back on trans-brake once you squeeze trigger, that is what mostly got it approved as for a safety feature on down track trans-brake mis-haps.
01-07-2010, 04:36 PM | #6 |
Re: Trans Trigger
Is there a web site and or pictures to look at this devise?
01-07-2010, 07:04 PM | #7 |
Re: Trans Trigger
dragraceresults.com bracket talk forum and ask under general discussion.
01-07-2010, 08:38 PM | #8 |
Liked 282 Times in 152 Posts
Re: Trans Trigger
Neat idea we have used it before(borrowed one)--- They aint cheap either about $450 !!!!
Not sure if NHRA accepts then either---Neat idea and once you get used to it DEADLY CONSISTENT---Comp 387 |
01-07-2010, 10:47 PM | #9 |
Re: Trans Trigger
NHRA does accept them. We had it on Danny's dragster at Z-MAX the first race and got down to three cars.
01-08-2010, 08:28 PM | #10 |
Re: Trans Trigger
The web site is shootthelite.com. It isn't $450.00. They cost about $250.00. Very trick. Will never use a button again.
