Is any one using or experimenting with any kind of epoxy instead of using hard bloc or cement
I have an old prostock bowtie block this block has some sort of what it appears to be Epoxy filling the bottom inch of the water jackets. ANY CLUES ???
Liked 30 Times in 17 Posts
Bad,
I wonder if your block was leaking around the bottom due to excessive relieving for stroke and the put in a little epoxy to seal it up ? I did it once to fix a small blow through from a broken rod. As far as using it instead of Hard Block, I had a customer fill a block with some type of epoxy many years ago. The only thing I remember about it was that he ran the block ( 302 Ford ) for several years afterwards, and every winter when he was freshening it up, the bores had moved around a BUNCH ! I have never seen a block filled with Hard Block do that. Bill Koustenis Advanced Automotive Machine Waldorf MD
Bill Koustenis |
Liked 451 Times in 77 Posts
Probably Devcon epoxy. I've seen some older Pro stock pieces done with this. I agree with the epoxy moving around, heat definitely affects it.
I have seen blocks filled with cement move around also, RU saying that Hard Block does not move around like Cement or Epoxy.
Bad,
I have not seen a block filled with Hard Block move around much. The one that was filled with epoxy was a mess, if I remember correctly it kept getting tighter each year ??? Bill Koustenis Advanced Automotive Machine Waldorf MD
Bill Koustenis |
Back in the 70's I use Devcon epoxy and as a machinist I saved a pile of castiron shavngs etc and mixed them in with the epoxy to fill a 350 block for stock. I put a hose through the drain hole facing up towards the deck to keep the drain open. A few years later a buddy used the block for a bracket motor, Henry. (old 1608)
old 1608 stock racer |
