Old 01-08-2009, 06:01 PM   #1
cwoodW252
Default Head rest in first gen camaro
I have a 68 camaro with the low back seats, and was wanting to find out how the head rest is made off of the roll bar in other cars.
Thanks Chris
cwoodW252 is offline   Reply With Quote
Old 01-08-2009, 07:14 PM   #2
FED 387
Liked 329 Times in 177 Posts
Question Re: Head rest in first gen camaro
do you have a roll cage or a roll bar in your car??? If you have a roll cage you probably have a brace/support of some sort going behind the drivers seat from side to side -----If you do have it this way the way I did mine was to fabricate a piece of aluminum tubing about 2-3 inches in diameter with bolts thru it took it to a auto upholstery shop had it coverd to match the seats and then drilled holes in the brace and bolted it all together---Hope this helps Comp 387
Old 01-09-2009, 11:36 AM   #3
Jimmy R Parker
Default Re: Head rest in first gen camaro
Chris, ART has a kit that I used on my '67 Camaro with an eight point bar, it's complete with padding and upholstery (black only).
Jimmy
Jimmy R Parker is offline   Reply With Quote
