Old 10-31-2008, 11:07 AM   #1
trmnatr
Default Super Stock Question, 327
Pretty long here, I got Questions about the CURRENT Super Stock 327 engines rules
-I know the crank stroke cant exceed 3.263"
-I know you can use the GM or Bow Tie block, Due to cost im using an 010 with probally Milodon caps {maybe splayed but probally not being its a wide register block, probally just use Milodon caps that use the factory 4 bolt holes}
-Im using Manley Super Stock legal rods
You used to be able to use a light weight piston {Super Stock} of the same top design, or if it was a dome it had to be no more dome volume than stock but could be lighter -- Is this still the case?
You used to be able to use .031" Dykes top rings, Is this still the case?
The engine will be a 327 10:1, the heads are -291's @ 57.5cc's. Is it still fine to use an .875" wrist pin?
Also, Instead of using the 1.625" H-11 or Manley NexTek 1.64" valve springs, has anybody switched to the PAC1226 which has the same pressure as those two springs but is a 1.55" O.D
Im under the impression they lifted the rules allowing you to run any powerglide, TH400, TH350. Is this the case?
I could not find any information on this on the NHRA site or IHRA - Not sure what we will run in but it will be most likely IHRA which operates off NHRA as a director told me
Do they have any restrictions on oil pans in Super Stock? Also, 10 years ago we would have filled the block with Hardblok, Is the rest of the class using 010 blocks and such doing so?
Also, Timing chain or belt drive?
Any rules on Electric water pumps?
Are Lift bars with adjustable uppers legal as of NOW in Super Stock?
What class would this engine be in if used in a 3750 race weight car in GT, GT/H????? What would be the index in the class this car would fall under?
Thanks for the help !
trmnatr is offline   Reply With Quote
Old 10-31-2008, 08:35 PM   #2
Bobby Stevens
Wink Re: Super Stock Question, 327
Dear trmnatr, I used to run a 327 in my car and did my own machine work at the shop I worked at. The crankshaft you have +/- .015. As far as the block goes be very carefull when you mill it because when we did mine you have to take so much off we started pulling threads out of the block so I had to start putting in heli coils in. You can run any piston/pin combo you want. Rings are the same way. You can use any size valve spring you want. More than likely you will be using a triple spring on both intake and exhaust. What I would do is take the weaker ones and put them on the ex. and put the new ones on the in. Any water is legal and the best thing is a belt drive from jesel or comp cams. If you have any other question you can contact me at maverickmotorsports5456@msn.com
Bobby Stevens
Bobby Stevens is offline   Reply With Quote
