Old 11-12-2008, 08:45 PM   #1
Chris Hill
Liked 244 Times in 26 Posts
Default 1996 Powerstroke Dies Intermittently
Hello,
I have a 1996 F-250 powerstroke diesel. The past couple of days, it has been running fine, then dies. It dies like the key has just been turned off. Luckily, the truck has restarted every time thus far and I have not been stranded. It will die momentary, less than a second or two. Only once did it die enough I had to restart the truck with the starter motor. The truck has missed/died 5 times the past two days. Please help me solve this issue.
Since it’s a diesel and they way it’s dying, I REALLY think I have an electrical issue that is interrupting the signal for the injectors to fire.
The battery idiot light (looks like a battery and is red) has been VERY sporadically flickering the past couple of months. Generally it will flicker on a bumpy road. Again, the voltage has been rock solid and the truck has run well until this point. I’m not sure if the idiot light flickers when the truck dies yet.
When the truck dies, the head lights and dash lights do not dim. I’ve checked the battery terminals and ground straps to the engine and they appear to be good. Also, the voltage meter on the dash does not move, it stays 14V. When the truck is running, the volt meter reads approximately 14V.
I’m thinking I have a loose ground somewhere, but have no idea where to look other than the obvious points on the battery and negative terminals on the engine. The part that puzzles me is when the truck dies, the volt meter does not change. If you have any ideas on what to check, please share.
Thank you,
Chris Hill
270-933-2054
Chris Hill
Old 11-12-2008, 09:11 PM   #2
Rich Aman
Liked 10 Times in 3 Posts
Default Re: 1996 Powerstroke Dies Intermittently
Chris,Check all the grounds around the batts,( the 10 ga. wires that run off the neg cables),also a quick connect that gets batt acid in it on the pass side10 ga ground cable.
If all looks good replace the ignition switch,over the years i've seen a lot cause trouble.
Good luck
Rich Aman,1631 G/S
Rich Aman is offline   Reply With Quote
Old 11-12-2008, 09:11 PM   #3
Steve OB
Steve OB's Avatar
Send a message via Yahoo to Steve OB
Try this site. It seems to be pretty informative.
http://thedieselgarage.com/forums/
Steve Obertanec
Steve OB is offline   Reply With Quote
Old 11-12-2008, 09:50 PM   #4
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
try the CPS (cam position sensor) on the front cover just below water pump. A very common PSD part that does exactly what you're describing when it goes bad.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 11-12-2008, 10:02 PM   #5
Rob Petrie E395
Liked 216 Times in 77 Posts
X2 Cam sensor is almost always the problem most ford dealers stock them due to their frequently going bad
Old 11-12-2008, 10:31 PM   #6
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
My 96 powerstroke had the same problem, last month, and it liked to die going around turns (not good for a rollback!), I suspected a lot of expensive, dramatic things.....
The local diesel shop swapped out the cam position sensor for me and its as good as new.
I purchased another one from Wabash Ford off ebay for something like 15 bucks for the dash for a spare.
You will need a 10 mil wrench.
You might want to call the ford dealer first before you schedule it, the part according to them was $150 bucks.
Eric Merryfield 1883 STK
Old 11-12-2008, 10:49 PM   #7
art leong
Another helpful site is
http://www.thedieselstop.com/
Art Leong 2095 SS
Old 11-12-2008, 11:25 PM   #8
Pat Cook
Cam Sensor.........put the latest level in it.....
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
Old 11-13-2008, 12:01 AM   #9
Chris Hill
Thanks for the replies. I'll try and get a cam sensor tommorow.
Could the cam sensor cause the battery idiot light to go off?
I also need to change glow plugs. Any recomendations of brand to use?
Thanks,
Chris
Chris Hill
Old 11-13-2008, 12:10 AM   #10
SSDiv6
Thanks,
Chris
Chris, you can get the Autolite Glow Plugs at the following website:
http://www.sparkplugs.com/results_ap...1&AAIA=1354643
They are great to do business with.
