Old 05-25-2008, 03:22 PM   #1
Ed Wright
Ed Wright's Avatar
Default Trans brake "sticks"?
Guys, I have not used a trans brake much, and know nothing about automatic transmissions, so need some advice. I found mine (last night) to stick, engine is off. I first thought it was the button, or a fuse.It stopped making a noise when I pushed the button. I was changing spacers. I found I can tap it (The solenoid in the trans) lightly and it pops back off. It has a very light spring. It is Rossler T350. I don't know if line pressure will keep it from happening on the starting line or not? I have another one in another transmission about 45 miles from here. I may need to go get it for Topeka next week. Looks like it just screw in the case?
Thanks, Ed
Ed Wright 4156 SS/JA
Old 05-25-2008, 03:39 PM   #2
SSDiv6
Default Re: Trans brake "sticks"?
Guys, I have not used a trans brake much, and know nothing about automatic transmissions, so need some advice. I found mine (alst night) to stick, engine is off. I first thought it was the button, or a fuse.It stopped making a noise when I pushed the button. I was changing spacers. I found I can tap it (The solenoid in the trans) lightly and it pops back off. It has a very light spring. It is Rossler T350. I don't know if line pressure will keep it from happening on the starting line or not? I have another one in another transmission about 45 miles from here. I may need to go get it for Topeka next week. Looks like it just screw in the case?
Thanks, Ed
Ed, trans-brake selenoids are knows to go bad. For that reason, many racers carry a spare selenoid in their tool box. You can also take it out and clean it with brake cleaner.
Old 05-25-2008, 05:20 PM   #3
Ed Wright
Ed Wright's Avatar
Thanks. Is that one little thin spring all that makes it release? Or, does line pressure when the engine is running help kick it back? It has a hex-shaped section, do you know if it just screws in? My lights have been bad enough this year without the trans brake failing to release. One light tap with a screw driver handle made it pop back out both times it stuck. Is that unusual when the engine is not running? I don't remember hearing it fail to engage and release before. The whole trans was new this spring. As I said, this is kinda new to me. Always ran stick or foot brake cars "back in the day". My bank account thinks I should have stayed away. <G>
Thanks, Ed
Old 05-25-2008, 06:03 PM   #4
mrolds
mrolds's Avatar
My hipster t400 had a real light spring in it, & I think they said the pressure will keep it out.("pressure release") My current JW brake has a monster spring on it & has been giving me fits with the solenoid not engaging occasionally (usually 1st or 2nd rd) I think the case is swelling under heat & making the valve stick, because when you manually push it in it starts working again.
If your 350 is like the 400 ,& I think it is, the solenoid pushes into the case where the modulator went, & is held in by a bolt & retainer strap.
Jeff Smith S/ST- Pro/ET 5102
Creating the streetable S/ST Olds
mrolds is offline   Reply With Quote
Old 05-25-2008, 06:09 PM   #5
Ed Wright
Ed Wright's Avatar
Thanks guys!
Ed
