Old 04-15-2007, 11:02 PM   #1
junior barns
Liked 20 Times in 14 Posts
Default trans gears or rear gears
in order to get the quickest et to the 330 and not sacrifice 1/4 mile times which is best to use
1) lw trans gears with higher rear gears or
2) high trans and a little lower rear gear??
junior barns is offline   Reply With Quote
Old 04-16-2007, 09:13 AM   #2
Dave Goob Cook
Dave Goob Cook's Avatar
Default
Trick question!!
Stick or automatic?
How much HP and how much weight?
I will say this, only change the rear gear ratio to adjust your finish line RPM's.
"Despite the high cost of living, it remains popular"
Dave Cook
C375
"Despite the high cost of living, it remains popular."
Dave Cook
NHRA N375
Dave Goob Cook is offline   Reply With Quote
Old 04-16-2007, 10:26 AM   #3
junior barns
Default
automatic!!
stock elim car. just trying to figure the quickest way to get to the 330 mark without giving up et at the 1/4 mile. never mind mph
it seems that you can get about any gear ratio for the trans that you want, so i'm wondering if et is quicker this way instead of using the rear gear.
Old 04-16-2007, 12:47 PM   #4
junior barns
Default
thanks steve
upper class car 3speed 3500 to 3600lbs
Old 04-17-2007, 04:16 AM   #5
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Default
chevy? if small block MaClay 2.91 metric if big block 350th 2.75
novamoation
Old 04-17-2007, 11:05 PM   #6
junior barns
Default
steve
can I borrow that banana to push. it should be worth a tenth as much energy it has! [:-grin-:]
