Old 04-26-2007, 08:29 PM   #1
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Default Ford HELP....
I am finishing our new car and am going to try to run the Stock 302 I already have.. I have already changed it to a carb setup, using a Parker Funnel Intake with a 650 double pumper... I also have a X303 cam for it... I will be using a MSD distributor, and 6AL ign. box... it will be mated to a P&A full Man. C-4 no brake with a 3200 TCI conv... the car has been tatefully lightened, doors gutted, QA1 tubular front end with thier Coil overs.. on the rear I have Soutside Lift Bars, and Dbl Adj Uppers... stock 8.8 with a 3.73 posi and M/T street slicks.. 26x10's...the car has had a full cage added to it, but anything not needed inside the car was removed.. all the harness, heater/ac box, guage cluster everythng..
I am trying to get this car to run high 11's I know I will need some more power.. thinking about a 125 shot of N2O..
do you guys think I can get there? or do I still need more engine???
This is being built to bracket race.. but since you guys are limited so much in the engine area I thought I would post here for some help..
Thanks
Freddie
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 04-26-2007, 10:43 PM   #2
Stephen J
Default
you should be in the 11s easily with the 125 shot. I hope you got some good pistons though. my daily driven 302 ran 11.50s on motor, but now runs 10.90s
Stephen Johnson #2162
Horace Johnson #2167
Stephen 2162
Horace2167
Stephen J is offline   Reply With Quote
Old 04-27-2007, 02:07 AM   #3
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Default
I like to see more carb & converter but....stephen would know better then I. the NOS is a big help to the combo. looks like more like a 12.40 car to though?
novamoation
Old 04-27-2007, 03:36 AM   #4
Stephen J
Default
Are you using the stock heads(E7TE). If so you better junk them because those heads with a funnel web intake is goin to kill it.
Ex-Jim Van Cleve
Stephen 2162
Horace2167
Old 04-27-2007, 06:41 AM   #5
Freddie
Freddie's Avatar
Default
for now yes they are stock e-7 heads... I am planning on getting a set of Aluminum heads but have to wait for the budget to allow it...
would I be better off leaving the Performer intake on it till I switch heads?
Old 04-27-2007, 11:51 AM   #6
Stephen J
Default
yes, you could use the performer or better yet the weiand stealth or air gap intakes are the best dual planes for a carb. You said you were goin to use the stock heads..... you will only get low to mid 12s on that 125 shot. Get a good set of alum heads, and you will be where your goal is.
Stephen 2162
Horace2167
Old 04-30-2007, 09:14 PM   #7
Freddie
Freddie's Avatar
Default
thanks.. I have been looking for a set of older 351 W heads they had a little bigger valves, and bigger ports.. flow better than the GT40 heads.. if not I will wait till I get the Aluminum heads..
Old 05-01-2007, 11:25 AM   #8
Chris1529
Liked 70 Times in 29 Posts
Default
what year is this car? An older GT (83-86) or LX (87-97) may run high 11's where as a GT (87-93) (94-95) are heavier cars that may only go mid 12's. There is about a 400 lb difference among some of these cars.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 05-01-2007, 12:29 PM   #9
Freddie
Freddie's Avatar
Default
the car is a 89 GT.. but has been put on a major diet... anything not needed to hold something down has been removed... the doors have been gutted and the windows pinned up in them then the interior put back over ... everything behind the dash is now gone... along with the stock front end in favor of a QA1 setup..
I figure I am about 450# lighter than when I started...
would love to get in the high 11's on the stock engine , without needing to go with a trans brake...
Old 05-01-2007, 04:23 PM   #10
gto whippet
Default
freddie e mail me i have a set of 1970 351 widsors bdahms@ipns.com 503 635 1310
gto whippet is offline   Reply With Quote
