Old 06-23-2024, 01:48 PM   #11
CMcAllister
Liked 787 Times in 222 Posts
Default Re: Oil Accumulator Solenoid Valve
Originally Posted by curtis reed View Post
My opinion having the Moroso valve, it's the best option. You could just use a ball valve and turn it on in the morning and off before shutting down at the end of the day. Cheapest option but not near as effective as pre-oiling at every start up.
I did that for one weekend. Ordered the Moroso valve Monday morning.
Moroso has good stuff. I'm sure there are cheaper (i.e. made by slave labor) alternatives.
And wire the thing to a dedicated switch so you can control when it's open, and when it's not so it can recharge. The big advantage is it will act as a diode and allow the can to recharge without allowing the oil to escape when the engine is off.
CMcAllister is online now   Reply With Quote
Old 06-23-2024, 01:57 PM   #12
CMcAllister
Originally Posted by 1320racer View Post
why?
Pre-lube the engine and I don't have a magic oil pan.
Why not, other than weight?
Old 06-23-2024, 10:09 PM   #13
SDT1DYI
Liked 426 Times in 134 Posts
I would guess the Mororso valve maybe manufactured by ASCO.
They are one of the largest manufactures of various type
Solenoid valves.
SDT1DYI is offline   Reply With Quote
Old 06-24-2024, 09:42 AM   #14
Cdncarnut
Cdncarnut's Avatar
Liked 51 Times in 31 Posts
Solenoid valves.
I thought that it was Goyen who made the Moroso valve.
Thomas
NHRA 1959 D/SA
Cdncarnut is offline   Reply With Quote
Old 06-24-2024, 12:20 PM   #15
curtis reed
Liked 101 Times in 56 Posts
I thought so also.
curtis reed is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
