Old 06-21-2024, 09:37 PM   #11
Jeff Stout
Liked 691 Times in 274 Posts
Default Re: Tow truck tranny issues, back again
Input speed sensor sounds very promising
Old 06-22-2024, 09:30 AM   #12
Liked 1,218 Times in 313 Posts
A stand alone TCU is a waste. There's no reason to need one or go through the hassle.The stock stuff works fine, there's several million dollars worth of R&D behind them for reliability. Adding some stand alone controller requires more wiring harness and adapting/interfacing that just adds complexity, and does not guarantee a solution.
It's more likely to be a wiring harness problem than an ECU. The wiring diagram for your truck can be found online, probably for free.
There are two ATSG manuals that are good for that transmission, one is a dedicated rebuild manual, the other is a manual that covers it and the 4L60E, and includes the electronic/electrical diagnosis.
Old 06-22-2024, 10:18 AM   #13
Mark Ruset
Mark Ruset's Avatar
Liked 35 Times in 25 Posts
i was a GM service manager for many years, when we would see problems like this we usually found that the pin tension on the harness was not adequate for a proper connection. It is very important that you probe the terminals with the proper pin connectors, if someone used a test light or an ohm meter to check for continuity than they may have spread the terminals just enough to make for a poor connection. Make sure your shop has the proper tools to diagnosis this concern.
Mark Ruset 2048 STK
Mark Ruset is online now   Reply With Quote
Old 06-22-2024, 12:42 PM   #14
BTR69
BTR69's Avatar
Liked 60 Times in 17 Posts
You make a great point on the TCU. I'll research the manuals you've referenced. Waiting on rain to pass here so I can get back under it and swap the input speed sensor. Thinking about swapping the neutral safety switch as well. I found a new one yesterday that had been picked up for another truck that has been sold. Nice to find stuff I had long forgotten about. As long as it's the same part from 95 to 98 anyways. I'm optimistic. I'll pull up wiring diagrams as well. Thanks for the info.
William Kilduff
1970 Barracuda (still under construction, indefinitely)
1968 Camaro SS/C
BTR69 is offline   Reply With Quote
Old 06-22-2024, 12:44 PM   #15
BTR69
BTR69's Avatar
I'll certainly keep this in mind. Thanks.
William Kilduff
1968 Camaro SS/C
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
