Old 09-18-2024, 08:58 PM   #11
Glenn Briglio
Glenn Briglio's Avatar
Liked 903 Times in 285 Posts
Default Re: Thrust problems with two step in Stock
I can tell you I cracked two cast crankshafts using a two step box. I don't use cast cranks or two steps anymore and no problems.
Old 09-19-2024, 01:27 AM   #12
Adger Smith
Liked 740 Times in 285 Posts
John,
For years I have put thrust pressure oiling on engines that use a 2 step or Trans brake.
It is a simple modification to the bearing.
Upper thrust bearing only or the block side
side of bearing opposite the notch
rear half of this bearing to the rear of the oil channel
increase the parting line slightly by chamfering(.060)
It will allow some additional oil from the bearing's oil channel to trickle into the back thrust area under pressure.
Adger Smith (Former SS)
Old 09-19-2024, 06:41 AM   #13
Darcy Clarke
Liked 480 Times in 33 Posts
In 2017 I fought thrust bearing issues in my Superstocker. I researched everything I could find about it and made several changes. In the rear side of the thrust face I drilled a .060" hile through the thrust face into the oil gallery and then dressed the bearing to allow the pressure fed oil to cover the face. I also added ground straps from the transmission as well as the starter to ensure that there was no chance of a poor ground. Mopar starters bolt to the transmission. I measured the converter pull up and made a .060" shim for the Bell housing to increase my pull up. I switched my main caps to billet caps. I did no transmission modifications and my issues went away.
Darcy Clarke
6254
A/SA SS/EA
Darcy Clarke is offline   Reply With Quote
Old 09-19-2024, 10:19 AM   #14
Stocker 2046
Stock 2046
Back in my s/g days late 80;s alot of the 468" cars Ext. balanced would wear the thrust
flange about 100 runs. The 427 Int. balanced cars never had a problem.
Also make sure you bolt the trans up to the block and spin the converter
freely.
Regards
Stocker 2046 is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
