Wanted: Set of usable pistons for mopar 318
going a differ combo
Re: Wanted: Set of usable pistons for mopar 318
Are they flat top or with valve relief or either
way? I never raced that year as I hate 2 Brl carbs. |
You are fine and can pay me when
I deliver them to you! I am at Vegas races until after next week's divisionals. If you need them sooner = I can try to get home and ship them to you after Nationals. |
I did some checking and the 68 to early 70s pistons have
4 VALVE notches similar to 72/73 340 engines. You need to use them rather than flat tops or you will have nearly zero valve clearance with a stocker camshaft with correct lift. Sorry I did not know the early engines had a different piston. |
[QUOTE=GTX JOHN;695987]I did some checking and the 68 to early 70s pistons have
4 VALVE notches similar to 72/73 340 engines. You need to use them rather than flat tops or you will have nearly zero valve clearance with a stocker camshaft with correct lift. Sorry I did not know the early engines had a different piston.[/QU ok, guess i will just have to go with the ross pistons. the class whides to not mention the valve reliefs |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
